i have installed OSMC on my Raspberry Pi 3B+ and configured with static IP through the My OSMC app. This worked and i got my static ip.
However, after doing that i’ve installed docker to run hass.io on it but soon after the first reboot i noticed that the device is no longer getting a static ip.
whats odd is that if i go back to the my osmc app it still shows that the ip is manually set but instead of showing the ip that i gave it it shows the ip its getting from dhcp.
i tried changing settings via connmanctl, but although it works the moment i run the command, when i reboot it retakes the dhcp ip while still showing its using a manual ip.
cant figure this out, any help?
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Thank for getting back to me so fast.
This is the url: https://paste.osmc.tv/onuqezexil
You actually installed a bunch of packages, including docker and network-manager.
You need to remove the network-manager package, since it breaks OSMC, as you’ve found.
sudo apt-get purge network-manager
that was it. thank you for helping.
I believe the extra packages where needed while building the hassio docker image.
