OSMC automatically updated some time this weekend, and now my Hifiberry dac plus is not functioning. Aplay -l doesnt find any soundcard
in Kodi under Settings/System/Audio the soundcard is not listed.
I had a similar issue a few days (or so) ago - updating was done today, unfortunately, it did not solve the problem. RIght now I run OSMC Kodi 15.2 Sep 28 2015 , Kernel 4.2.3-3-osmc, its a digi+ 1.0, and on a Pi-1-B+
(Nice thing - originally, the card was automatically detected on installing osmc - I just had to select it in the audio-hardware settings).
Solved it: There are two places needing a correction (following the update, I assume)
First of all:
My OSMC → Pi Config (starting awkwardly slow with me ~10sec) → Hardware support → Soundcard overlay: set to “hifiberry-digi-overlay”
Then
(sorry as my system is set to German)
Einstellungen → System → Audio Ausgabe → Ausgabegerät: set to "ALSA: Default (snd_rpi_hifiberry_digi_S/PDIF)
Sorry for posting early, but I tried 2 hours to solve it before posting… As it takes this awkward 10 sec+ to enter “PiConfig” in OSMC, I happened not to be patient enough.
Hope it helps anybody.
Hi Oli,
I’m trying to do as you wrote, but changes made in Pi Config are not stored. After setting to “hifiberry-dacplus-overlay” and confirming by OK button changes are not stored Anyone can help with this issue?
I’ve got OSMC Deceber 2015 version
EDIT I managed the problem by editing config.txt file manually but configure by Pi Config still doesn’t work.
END EDIT
