after a reboot, i lost all my configurations concerning the menu and/or my sources for movies.
Some Bluray iso`s crash the kodi and the vero makes an reboot.
before the last update everythink works fine , no chrashes.
is the problem known and how can it be solved?
Kodi Version 18.3, compiled 2019-08-05.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
By “after a reboot” you mean after you installed the last OSMC update and rebooted, correct?
Regarding menu and sources can you clarify this a bit on exactly what was changed? Is this still the case or did you already change things again and so what the log currently shows is not this defective state? Were you using the Confluence skin before the update or something else?
Can you nail down what the common denominator is between what does, and what does not crash?
Can you go to settings>player>videos>adjust display refresh rate> and set that to “on start/stop” and then check to see if the crashes remain.
