I have a Raspberry Pi using OSMC with a wired network connection and a static IP address. It all works great and I am using various iThings as remote controls.
This was fine until the other day when I couldnt use any of the remotes and the Pi wasnt responding to any Pings. I reset my router and tried to login with Putty but had no network access. Tried a re-install which worked fine for a few days then had the same problem.
The only option was to power off then on again, after which it would not boot and there was a blank screen. I am after some help on 2 things, firstly a way to get the Pi to reboot even though the network is down??
Secondly, Im not sure of the workings but if I power down the Pi without shutting down it appears to kill OSMC. Any thoughts on this??
