Hi all,
I had a prompt for a OSMC update for a few days / weeks or so and tonight finally applied the update. Since the update the TV seems to have a black invalid format message bouncing around.
If i reboot the PI via SSH i can see the OSMC splash screen then it goes back to been black and invalid format message. I know the PI is booting as SSH / WWW is up.
Pretty sure its resolution related as my TV is quite old and supports upto 720p. Was working fine prior to the update.
Below is the output from the logs.
https://paste.osmc.tv/uqojucupeg
I’ve also gone some googling and output from these commands
osmc@osmc:~$ tvservice -s
state 0x12000a [HDMI DMT (6) RGB full 4:3], 640x480 @ 75.00Hz, progressive
osmc@osmc:~$ tvservice -m CEA
Group CEA has 16 modes:
mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
(native) mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced
mode 22: 720x576 @ 50Hz 16:9, clock:27MHz x2 interlaced
mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive
mode 32: 1920x1080 @ 24Hz 16:9, clock:74MHz progressive
mode 33: 1920x1080 @ 25Hz 16:9, clock:74MHz progressive
mode 34: 1920x1080 @ 30Hz 16:9, clock:74MHz progressive
osmc@osmc:~$ tvservice -m DMT
Group DMT has 11 modes:
mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 6: 640x480 @ 75Hz 4:3, clock:31MHz progressive
mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
mode 11: 800x600 @ 75Hz 4:3, clock:49MHz progressive
mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
mode 17: 1024x768 @ 70Hz 4:3, clock:75MHz progressive
mode 18: 1024x768 @ 75Hz 4:3, clock:78MHz progressive
mode 23: 1280x768 @ 60Hz 15:9, clock:79MHz progressive
mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
(prefer) mode 39: 1360x768 @ 60Hz 16:9, clock:85MHz progressive
mode 82: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
I’ve tried a few settings in /boot/config.txt but since hashed out the entrys at it made no difference.
Can anyone help? Its my first post so please bare with
