MariaDB UI glitch
@Tee77 Thx for the logs which help a lot. Atm all database queries came back within 10 ms which is faster than the MariaDB installation on my RPi 3 B+ where all “SELECT * FROM season_view WHERE …” where answered with a max. of 24 ms without showing this wait message.
There must be another root cause for this than the current database installation.
This is the way to try. I see also that you have installed the jurialmunkey repository. No idea whether this is related. However, for a system customized in this way, we cannot invest much more time in identifying the cause of such cosmetic issues.
2026-11-04 11:14:42.128 T:3032     info <general>: CAddonMgr::FindAddons: repository.jurialmunkey v3.5 installed
It might be most productive if your comfortable with some mild terminal work, to just try it with a temporary clean install to make sure there isn’t any customization in your Kodi userdata.
Enter the following commands with an SSH connection.
systemctl stop mediacenter
mv ~/.kodi ~/kodi.bak
systemctl start mediacenter
cp ~/.kodi.bak/userdata/advancedsettings.xml ~/.kodi/userdata/advancedsettings.xml
systemctl restart mediacenter
This will get you Kodi up clean with just your connection to your MySQL database. To restore your original Kodi userdata after this test you run the following…
mv ~/.kodi ~/kodi.bk2
mv ~/kodi.bak ~/.kodi
If your original setup was restored as expected and you want get rid of the unneeded clean install you can delete that with the following command.
rm -r ~/kodi.bk2
Clean install made no difference.
I wouldn’t have thought tmdb helper would be affecting things - not a dodgy addon - but worth a shot. Thanks anyway.
Did you also opt against using the MDBList scrobbler by Linas Purinis during the fresh installation?
It appears that you are following specific instructions to manually edit the “advancedsettings.xml” file. OSMC provides a menu—accessible via “Settings” → “My OSMC” → “Network” → “MySQL”—where you can enter all the necessary details for your external database; all required information is then automatically incorporated into the “advancedsettings” file.
I did - started from a fresh install without tmdb helper or mdblist addons. No improvement.
Thought I’d dig out my Odroid to test on a different device. Estuary skin behaves much better - a very minor flicker of the highlight bar when entering/exiting episode view, but no flickering text- no issues with that at all. Guessing that’s a completely normal, minor delay when accessing the MySQL database.
Tried Estuary on Vero and that’s actually very similar - slight flicker in highlight bar but no flickering text.
The odd thing about the osmc skin is that half the time, the transition into episode view is smoother than Estuary skin on either device - almost indistinguishable from accessing local database directly - but the other half of the time exhibits glitchy text when entering/exiting episode view.
I realise this is a cosmetic issue as MySQL is working as it should, but it’s distracting enough to make me not want to use this setup.
Didn’t realise I could set this up via Myosmc. Tried it off a clean install. Worked, but made no difference.
Sorry to bother you again - found time to do some further testing and would appreciate your thoughts.
Both native and docker mariadb server installs on rpi5/ raspberry OS result in the visual glitch on Vero when entering and exiting episode view. Tried changing pi’s ethernet cable but made no difference.
Setup LibreELEC on pi5 and used its Mariadb server addon. Same glitch.
Setup CoreELEC on Odroid and used its Mariadb server addon. Same glitch.
Installed MariaDB on Vero itself. Perfect performance, and the second Vero exhibits no visual glitches when accessing the database from the Vero hosting the server.
Any ideas why this could be the case? I’m guessing this rules out a network issue?
If this is the only solution that works for me, is hosting Mariadb server on Vero resource intensive or is it relatively lightweight? Thanks.
The Vero’s have plenty of headroom to run it fast on any common library size.
On the CE and LE installs did you experience the glitch on those devices themselves, or were you just using them for the MariaDB instance? If the latter then you were still using the same network path with those tests I’m assuming and with the Vero it is a bit different. As far as I’m aware OSMC does not customise its MariaDB install at all and as such should be exactly the same as with the other OS’s. It could be that your TP-Link switch has gone a bit wonky. I’ve seen it before, working but a single port or more doesn’t work, or work correctly. They make very good switches for the money, but they still are budget switches.
Thanks. That’s good to know.
Fair point. I connected the rpi hosting mariadb server on raspberry os native install direct to router - same result. I also tested the Odroid’s mariadb server using the ethernet lead/ tp link port from the second Vero (which worked perfectly when accessing my main Vero’s mariadb server) and still saw the exact same glitch on my main Vero.
I tried accessing the rpi’s mariadb server from the Odroid a few days ago when initially trying to diagnose the issue - I only used Estuary, but there were no visual glitches (same with Vero on Estuary skin - a very slight flash of the coloured highlight bar but no ‘please wait’ flickering or double vision/ ghosting text type effect on tv show name that I see on osmc skin)
Try to check network with iperf3 or as a starting point a ping between the devices
Please read this howto
Vero 1 (mariadb host) and Vero 2 are showing no signs of the glitch when accessing media, so decided to create fresh instance of kodi on Vero 1, power down Vero 2 and attach its network cable to Odroid N2 which is hosting it’s own mariadb server. Vero 1 is still showing glitches when accessing Odroid’s Mariadb server.
Here’s the iperf results…
osmc@osmc:~$ iperf3 -R -c 192.168.0.35
Connecting to host 192.168.0.35, port 5201
Reverse mode, remote host 192.168.0.35 is sending
[ 5] local 192.168.0.6 port 53890 connected to 192.168.0.35 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 111 MBytes 928 Mbits/sec
[ 5] 1.00-2.00 sec 112 MBytes 941 Mbits/sec
[ 5] 2.00-3.00 sec 112 MBytes 941 Mbits/sec
[ 5] 3.00-4.00 sec 112 MBytes 941 Mbits/sec
[ 5] 4.00-5.00 sec 112 MBytes 941 Mbits/sec
[ 5] 5.00-6.00 sec 112 MBytes 941 Mbits/sec
[ 5] 6.00-7.00 sec 112 MBytes 940 Mbits/sec
[ 5] 7.00-8.00 sec 112 MBytes 941 Mbits/sec
[ 5] 8.00-9.00 sec 112 MBytes 941 Mbits/sec
[ 5] 9.00-10.00 sec 112 MBytes 941 Mbits/sec
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec receiver
iperf Done.
osmc@osmc:~$ iperf3 -c 192.168.0.35
[ 5] local 192.168.0.6 port 53896 connected to 192.168.0.35 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 112 MBytes 942 Mbits/sec 0 339 KBytes
[ 5] 1.00-2.00 sec 112 MBytes 937 Mbits/sec 0 373 KBytes
[ 5] 2.00-3.00 sec 113 MBytes 944 Mbits/sec 0 373 KBytes
[ 5] 3.00-4.00 sec 112 MBytes 937 Mbits/sec 0 395 KBytes
[ 5] 4.00-5.00 sec 113 MBytes 946 Mbits/sec 0 395 KBytes
[ 5] 5.00-6.00 sec 112 MBytes 937 Mbits/sec 0 395 KBytes
[ 5] 6.00-7.00 sec 113 MBytes 945 Mbits/sec 0 413 KBytes
[ 5] 7.00-8.00 sec 112 MBytes 936 Mbits/sec 0 413 KBytes
[ 5] 8.00-9.00 sec 112 MBytes 943 Mbits/sec 0 413 KBytes
[ 5] 9.00-10.00 sec 112 MBytes 937 Mbits/sec 0 413 KBytes
[ 5] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 1.09 GBytes 939 Mbits/sec receiver
iperf Done.
Very confusing situation: Can you describe your intranet structure means which Vero and the MariaDB Pi is connected to what switch and router and the connection between like ethernet, power-line, etc.
@Tee77 warning:
The RunQuery entries in the debug logs proved this assumption to be wrong. Google’s Gemini analysis of the previous post states Jessica’s response is AI generated with a probability of up to 90%.
jessicawilson has been escorted out of the building.
Ok noted, thanks.
Sure. I’m planning to bypass my network switch tomorrow eve, connect devices directly to the router and retest, but my current setup has all devices (2x Vero Vs, rpi5) connected to a TP-Link network switch which is connected to my Sky router. Pretty simple setup - all switch and router settings are default.
With Vero 1 hosting Mariadb, Vero 1 and Vero 2 perform perfectly when accessing the database. All through network switch.
As mentioned before, I’ve also tried using a CoreELEC device’s MariaDB server addon (using Vero 2’s Ethernet cable) and see the glitch on Vero 1.
I’ve also tried the rpi running MariaDB server natively, via docker, and on a LibreELEC install (connected to switch and also directly to router, and with a different Ethernet cable) and both Vero’s exhibit the glitch.
I’ll report back after testing everything via router. I could be wrong (and hope I am!) but given that the two Vero’s behave perfectly when one is hosting the database makes me think the switch or network isn’t the problem.
Mmmhh, if you have running MariaDB natively on your RPI 5 and connected Vero1 and Vero2 to the same switch … and you see the issue only on Vero1, I suggest to swap just for tests the Vero boxes but leave cables, power-supplies, etc. and check whether the problem moves with the Vero1 box.
If so… try performing a full reinstall of the Vero 1 – use the latest OSMC image for the Vero V to do this.
If not: There is something outside of the Vero1 in this setup that is causing the problem, but the box itself is not the cause.
Hi @JimKnopf
In this scenario, both Veros exhibit the glitch.
However…progress!
Instead of installing the LTS version of Mariadb on the pi, I decided to install the exact Mariadb version that the Vero uses when hosting the server (10.5.29) on the pi.
Set up fresh instances of kodi on each Vero and pointed them to pi’s database. Now, both Veros perform perfectly - zero glitches in sight. Network setup unchanged.
I then set up fresh instances of kodi on both Veros again, deleted docker container/ bind mounts from pi, and installed LTS docker version on pi - glitch is back.
So something to do with Mariadb version is causing this issue.
Thx a lot for this finding and sharing your experience.
Finally, could you please let us know which version of the MariaDB server you were using when you encountered the problem, and which OS and version you were running on the Pi?
No problem. I hope, rather than being a PITA, I’ve found something that can make a small improvement to Vero. Maybe not though, let’s see.
Sure. I don’t know which Mariadb version was installed natively on Pi as I’ve since removed it. Would rather not install again but if helpful, I’ll do it - just let me know. I do know I used the standard command to install - sudo apt-get install mysql-server.
The two docker images below made both vero’s glitch when accessing:
image: mariadb:lts
mariadb from 12.3.3-MariaDB, client 15.2 for debian-linux-gnu (aarch64)
image: lscr.io/linuxserver/mariadb:latest
mariadb from 11.8.9-MariaDB, client 15.2 for Linux (aarch64)
here’s my rpi5’s OS, which all native/ docker installs have been running on::
pi@raspberrypi5:~ $ cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 13 (trixie)”
NAME=“Debian GNU/Linux”
VERSION_ID=“13”
VERSION=“13 (trixie)”
VERSION_CODENAME=trixie
DEBIAN_VERSION_FULL=13.7
ID=debian
pi@raspberrypi5:~ $ uname -a
Linux raspberrypi5 6.18.60+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.18.60-1+rpt1 (2026-11-03) aarch64 GNU/Linux
anything else you need just let me know
