Maybe same topic, another DV playing problem in purple?
hi,
lately see a lot of topics of people with purple DV content. one said visionquest didn’t play, same here.
But it’s not profile 5, but 8.1. I compared with another 8.1 file.
the one that doesn’t play:
Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile A, HDR10+ Profile A compatible
one that plays fine :slight_smile: Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile B, HDR10+ Profile B compatible
So I read a bit, and it seems Profile A had bad metadatastructure and doesn’t pass info on well enough.
I presume you know all of this. Will this be fixed in the coming update as well ?
Edit : doing a skip (30sec) seems to force the TV to accept it. Plays in hdr then though, not dv
If you are playing Dolby Vision, HDR10+ detail is irrelevant. I can’t possibly say more without logs and/or a sample which shows the problem.
here are the logs
and here is a sample I made : SwissTransfer - Send large files securely and free of charge
I started ep1, then ep 2, then got a blue sad face ..after kodi started again, put ep 1 again
https://paste.osmc.tv/nojodikuze
here also the media info of 1 file :
General
Unique ID : 255624885871918407068273714182551330612 (0xC04F8FEDDAE342022EF33A5EA1E55F34)
Complete name : F:\TV\Visionquest\VisionQuest.S01E01.No.Strings.2160p.DSNP.WEB-DL.DDP5.1.Atmos.DV.HDR.H.265-FLUX.mkv
Format : Matroska
Format version : Version 4
File size : 4.82 GiB
Duration : 53 min 21 s
Overall bit rate : 12.9 Mb/s
Frame rate : 24.000 FPS
Writing application : mkvmerge 100.0 (‘Do Hot Girls Like Chords’) 64-bit
Writing library : libebml v1.4.5 + libmatroska v1.7.1
Video
Format : HEVC
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile A, HDR10+ Profile A compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 12.2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.061
Stream size : 4.53 GiB (94%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : R: x=0.708000 y=0.708000, G: x=0.170000 y=0.170000, B: x=0.131000 y=0.131000, White point: x=0.312700 y=0.312700
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 293 MiB (6%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Dialog Normalization : -27 dB
compr : -0.28 dB
dmixmod : Lo/Ro
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -4.5 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -4.5 dB
dialnorm_Average : -27 dB
dialnorm_Minimum : -27 dB
dialnorm_Maximum : -27 dB
Thank you. This looks like the same issue that others have reported and is solved in the staging repo. But I can’t recommend you upgrade to staging. It contains a regression in Kodi that caused a slowdown in video when the OSD is brought up.@sam_nazarko is sorting that out.
Great! (well not actually :joy:)
But then I know it’ll get fixed soon. I got plenty of other things to watch in the mean time.
I’ll keep my eye out on the forum for the fix announcements.
Tnx for the quick look and reply!
There won’t be a forum announcement for the fix per se (although we’ll obviously update threads where users have reported an issue); as it’s a problem affecting the stable repository and not general release.
I think he means staging, not stable repo.
Indeed, typo.
