I’m using the latest version of osmc on a rpi3 with the confluence skin. Sadly I dont see the “media flags” except of the 3D-Icon for some movies. I guess kodi knows that the movie is in 3D because of my file naming structure. After I’m playing a movie, the icons will appear.
All my movies are correctly recognized with the universal movie scraper.
Since then I was using Kodi/SPMC at my amazon firetv and there I had all the media flags (Resolution, Cocec, Sound…) out of the box.
Thank you sam. I will give it a try.
Just to be clear: This is not just a problem with the confluence skin, it happens with all skins which support this media flags.
Edit: The last posting in this thread (No Media Flags On Videos From NAS Library) does the trick. (Enable “Extract video information from files” under Settings - Media - Videos)
I also had to enable the permission the delete and rename the files and enabled the settings to show the hidden files under Settings - Media - General.
