*.mkv with two or more audio tracks handling
Hi there,
I’m new to this forum so in the first place let me say HI :slight_smile:
I have a lot of MKV files that contain 2 audio tracks inside (english/polish) and would like to know how to change audio track on the fly (while playing) as I don’t have a clue how to do it. Beside aTV + CrystalHD I also have Popcorn Hour A210 player and there this option worked via the remote.
I have a standard aTV remote - do I need a different remote for that? Is this even possible?
Regards,
Bring up the osd while playing the file and click on the audio (speaker) icon.
You should see what to do from there.
Yup, there it is :blush:
Works, thanks, BTW is there somewhere in the WIKI a remote guide?
Regards,
You mean to remap a remote?
You should find somethibg on this forum, just search.
