I was out of my mind …
I do not understand why developers OSMC have put this filter…
this limit can be a problem for future hardware extensions.
The patch you’re working on will disable the filter completely to the dev / mem so you can work with all drivers or whenever you need to enter any single driver … es. in my case BCM 2835 ?
Hello Sam ,
I saw that there was an update a few days ago.
I wanted us know if it is possible to disable the filter of memory protection and if it is possible in that way .
Reinstalled everything and now it seems ok …
now I’m trying to run the radio module rfm01 to connect to my weather station but will wait to receive the data … think the raspberry Pi 2 there is something different in gpio or management of ic2 from Raspberry B …
