Hi all,
im struggling to get my ir remote to work with osmc. After few attempts to record lircd.conf of my keystorkes i still have problem with lag between my first key pressed and after thath the smae keys enters the loop and cant stop.
dpkg -l | grep lirc
ii armv7-eventlircd-osmc 1.1.6 armhf eventlircd for OSMC
ii armv7-lirc-osmc 0.9.0-5 armhf lirc for osmc
ii armv7-remote-osmc 1.1.6 armhf Remote support for OSMC, achieved with lirc and eventlircd
sudo systemctl status lircd_helper@lirc0
* lircd_helper@lirc0.service - lircd remote support
Loaded: loaded (/lib/systemd/system/lircd_helper@.service; static)
Active: active (running) since Wed 2015-08-19 01:01:13 UTC; 6min ago
Process: 251 ExecStart=/bin/sh -c /var/run/lirc/lircd-%I.sh (code=exited, status=0/SUCCESS)
Main PID: 256 (lircd)
CGroup: /system.slice/system-lircd_helper.slice/lircd_helper@lirc0.service
`-256 /usr/sbin/lircd --driver=default --device=/dev/lirc0 --uinput --output=/var/run/l...
after stopping lircd
sudo mode2 --driver default --device /dev/lirc0
i get pulses all the time, even without pressing keys on remote control. is that normal?
I have TSOP31238 IR receiver
and lircd.conf file
begin remote
name /home/osmc/lircd.conf
bits 16
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9041 4465
one 601 1650
zero 601 524
ptrail 599
repeat 9044 2213
min_repeat 1
suppress_repeat 6
pre_data_bits 16
pre_data 0x8020
gap 108087
toggle_bit_mask 0x0
begin codes
KEY_POWER 0x00FF
KEY_MUTE 0xF00F
KEY_UP 0x9867
KEY_DOWN 0x827D
KEY_LEFT 0x38C7
KEY_RIGHT 0x7887
end codes
end remote
