hello all,
I’m new in these things but I was searching during two days without results
I try to mount a My cloud Directory on a OSMC (raspberry) with the following command
sudo mount -t cifs -o guest //192.168.0.15/nfs /mnt/test an I always receive mount error (6) : No such device or adress
If I ping to 192.168.0.15 (WD My cloud) there is no problem. I can’t find why ? I base me on “IT Solutions Christian Zehaczek” but no results…
Could anyone help me ?
Many thanks
sudo mount -t nfs 192.168.0.15:/nfs /mnt/test
nfs is NOT cifs…
Thanks for your quick reply. you are right
now after your command : sudo mount -t nfs 192.168.0.15:/nfs /mtn/test
I receive following mount.nfs: Coonection timed out ??
What is the output of showmount -e 192.168.0.15
Export list for 192.168.0.15:
/nfs *
