my usb hd is automounted :
/dev/sdb1 on /media/SEAGATE 2TB type hfsplus(ro,nosuid,nodev,relatime,umask=22,uid=0,gid=0,nls=utf8,uhelper=udisks)
How can i change the umask parameter so i can mount it writable ?
Regards
Anton
Regards
Anton
I don’t recommend using HFS+ volumes on Linux
They will be mounted RO often when a dirty bit is set.
Just to expand on what Sam has said, the disk has been mounted as read-only, so in this case it’s not a umask issue.
See hfs+ mounted read-only on linux - Recherche Google for some possible solutions.
