Subject: Need Advice About SMB Library Sync, Movie Set Artwork, and Missing “Add Videos” Option on Vero
Hello,
First of all, thank you very much for all the help and knowledge shared in the forum. I have learned a lot from the community while setting up my Vero V and Kodi movie library.
I am currently using SMB shares together with tinyMediaManager (tmm), local NFO files, and local artwork for my movie collection, and I would really appreciate some advice regarding a few issues I am encountering.
- Difficulty verifying whether all tmm movies are correctly imported into Vero/Kodi
Originally, tmm showed around 3170 movies, while Vero/Kodi scanned more than 4100 movies.
I suspected Kodi was scanning unwanted files such as extras, samples, BDMV/STREAM files, or multiple versions separately.
After reorganizing different versions of the same movie into single folders and cleaning/rebuilding the Vero/Kodi library, its count dropped to around 2600 movies, and movie sets dropped to around 220 collections.
Now I am confused about what the real situation is:
Are some movies actually missing from the Vero/Kodi library?
Or is Kodi now correctly merging multiple versions into single entries?
Or are some folders/files no longer being scanned after the cleanup?
I would like to verify whether all movies managed by tmm have successfully entered the Vero/Kodi library.
Is there any recommended method, workflow, plugin, or tool to cross-check a large local SMB + tmm library with Kodi/Vero?
For example:
comparing missing titles between tmm and Kodi,
exporting/importing lists,
identifying skipped folders,
detecting duplicate or merged multi-version movies,
or checking whether some sources are no longer being scanned.
- Movie set / collection artwork not displaying correctly
In tmm, many movie collections already have posters and artwork downloaded correctly.
Inside Vero/Kodi’s Movie Sets interface, however, more than half of the collection folders still display only blank folder icons instead of collection posters.
If I open the collection, the individual movie posters display normally.
I have already:
- enabled local artwork usage,
- generated movie set artwork folders in tmm,
- configured Kodi/Artwork Beef style naming,
- pointed the movie set artwork path in Vero/Kodi to the correct artwork folder.
Even so, many collection root folders still do not display artwork correctly.
Is there any additional cache refresh, setting, plugin, or recommended procedure needed for Kodi/Vero to properly load local movie set artwork?
- “Add videos” option sometimes disappears completely
Occasionally, both File Manager and Videos menus no longer show the “Add videos” option at all. At the same time, plugging a USB drive directly into Vero V also produces no response.
After rebooting, the option sometimes returns again.
I am not sure whether this could be related to:
- a Kodi state issue,
- SMB mounting problems,
- USB mounting,
- skin/UI glitches,
- another underlying system issue.
Has anyone encountered similar behavior before, or knows what might cause it?
- Direct Baidu Netdisk Playback on Vero
Is there any Kodi/Vero plugin, addon, or recommended method that can directly connect to Baidu Netdisk (Baidu Cloud drive/ 百度网盘), so that Vero can directly decode and play video or audio files stored in the cloud? I found an addon related to google-drive in Vero software database.
Ideally, I am looking for something that could:
browse Baidu Netdisk folders directly from Vero/Kodi,
stream media files without manually downloading them first,
and support direct playback/decoding on the Vero device itself.
I understand this may depend on API limitations, unofficial plugins, WebDAV solutions, or external mounting methods, so I would really appreciate any recommendations or experiences from other users.
Thank you again for your time, patience, and all the support from the forum community. I really appreciate any suggestions or troubleshooting ideas.
Best regards,
James
