Have the following movie that is played as an audio file on the Vero 4k+
I’m on the latest stable version OSMC November 202.11-1.
Movie does play correct on laptop.
General
Complete name : \\hyperv\data\Movies\Peter Rabbit 2 The Runaway (2021)\Peter Rabbit 2 The Runaway (2021) - [WEBDL-2160p][H265][EAC3 ATMOS 5.1][EN][EMPATHY].mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42/dby1)
File size : 9.76 GiB
Duration : 1 h 33 min
Overall bit rate : 15.0 Mb/s
Encoded date : UTC 2021-07-01 13:03:55
Tagged date : UTC 2021-07-01 13:03:55
Video
Format : HEVC
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 14.2 Mb/s
Width : 3 840 pixels
Height : 1 592 pixels
Original height : 1 590 pixels
Display aspect ratio : 2.40:1
Original display aspect rat : 2.40:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.097
Stream size : 9.26 GiB (95%)
Language : English
Default : Yes
Alternate group : 1
Encoded date : UTC 2021-07-01 11:01:23
Tagged date : UTC 2021-07-01 13:04:09
Codec configuration box : hvcC+dvcC
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : ec-3
Bit rate mode : Constant
Bit rate : 768 kb/s
Maximum bit rate : 811 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 513 MiB (5%)
Language : English
Service kind : Complete Main
Default : No
Alternate group : 2
Encoded date : UTC 2021-06-26 06:45:51
Complexity index : Not present / 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Text #1
Format : Timed Text
Codec ID : tx3g
Duration : 23 min 58 s
Bit rate mode : Variable
Bit rate : 89 b/s
Stream size : 15.5 KiB (0%)
Title : English
Language : English
Forced : No
Encoded date : UTC 2021-07-01 13:04:08
Text #2
Format : Timed Text
Codec ID : tx3g
Bit rate : 109 b/s
Stream size : 19.2 KiB (0%)
Title : English SDH
Language : English
Forced : No
Text #3
Format : Timed Text
Codec ID : tx3g
Duration : 1 h 26 min
Bit rate : 85 b/s
Stream size : 54.0 KiB (0%)
Title : British English
Language : English
Forced : No
Text #4
Format : Timed Text
Codec ID : tx3g
Bit rate : 79 b/s
Stream size : 53.9 KiB (0%)
Title : French
Language : French
Forced : No
Encoded date : UTC 2021-07-01 13:04:09
Downloaded a different version that plays fine on Vero.
General
Unique ID : 297376804969029902944001378721126179750 (0xDFB8B078F420663069D7F4FE947863A6)
Complete name : \\hyperv\data\Movies\Peter Rabbit 2 The Runaway (2021)\Peter Rabbit 2 The Runaway (2021) - [WEBDL-2160p][HEVC][EAC3 ATMOS 5.1][EN][CMRG].mkv
Format : Matroska
Format version : Version 4
File size : 9.66 GiB
Overall bit rate : 14.8 Mb/s
Encoded date : UTC 2021-07-01 12:16:24
Writing application : mkvmerge v50.0.0 ('Awakenings') 64-bit
Writing library : libebml v1.4.0 + libmatroska v1.6.2
Video
Format : HEVC
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 13.8 Mb/s
Height : 1 590 pixels
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.094
Stream size : 8.97 GiB (93%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1083 cd/m2
Maximum Frame-Average Light : 422 cd/m2
Audio
Format : E-AC-3 JOC
Codec ID : A_EAC3
Bit rate : 768 kb/s
Title : English
Language : English
Default : No
Forced : No
Complexity index : 16
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English [SDH]
Language : English
Default : No
Forced : No
