I see that I have 120 movies if I go in through video>files>movies but if I use the movies at the main menu it shows 58.
https://paste.osmc.tv/dotequlehu
I believe I have the naming correct and everything per the wiki.
Looks like TMDB might be down, or you have some network issues:
2019-07-28 16:48:12.753 T:1536160480 ERROR: CCurlFile::FillBuffer - Failed: Couldn’t resolve host name(6)
2019-07-28 16:48:12.754 T:1536160480 ERROR: CCurlFile::Open failed with code 0 for https://api.tmdb.org/3/search/movie?api_key=f090bb54758cabf231fb605d3e3e0468&query=A%20Dogs%20Purpose&year=2017&language=en:
Here’s another error I see in the log. Any clue what this means?
2019-07-28 19:38:56.522 T:1678512864 ERROR: EXCEPTION: Non-Existent Control 300
2019-07-28 19:39:18.312 T:1536160480 WARNING: CPythonInvoker(80): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
And a bunch of these:
2019-07-28 18:50:40.478 T:1423925984 ERROR: Run: Unable to parse web site
2019-07-28 18:50:40.479 T:1423925984 ERROR: GetDirectory - Error getting
2019-07-28 18:50:40.948 T:1423925984 ERROR: CCurlFile::Open failed with code 404 for http://api.themoviedb.org/3/tv/152831?api_key=6a5be4999abf74eba1f9a8311294c267&language=en&append_to_response=external_ids,images&include_image_language=en,en,null:
UPDATE - I couldn’t ever get the default movie scraper to add them all to my library so I did it all locally using TMM (https://www.tinymediamanager.org/). I’ve got them all resolved properly now with each movie stored in a separate folder which includes images and the nfo file.
