MT7610U can it work possibly?
Hi all!
I have a USB WiFi card that can work with wifi AC (the 5GHz is the interesting, because we have dozen of AP-s around us at 2.4Ghz) the chipset ID is 0e8d:7610 (or mediatec 7610U but I have seen somewhere that it could possibly be RT2860 or RT2870 also).
Main thing is that I see the damn thing with lsusb when connected, and I can see in the firmwares directory that it has the necessary RT28X0.bin, but OSMC doen not recognises it. I have tried to google around but notnig much surfaced. The board is an RPi2. Can someone advice anything?
I have this on my to do list. I will see if I can add support soon
Glad to hear it. If I can be of any help in testing or other please just let me know.
Adam
Is something like an archer T2U 802.11ac with usb ID 148f:761a part of that same todo?
(in the meantime I tried to install drivers myself using this post after running
sudo apt-get install rbp2-headers-4.2.3-2-osmc
but to no avail, compilation still fails in something related to /build in the headers location :expressionless: )
Possibly the same chipset and different vendor. As far as I can see the main problem is that the driver for linux and for this chipset were made for 2.xy kernel and was never updated farther, so a lot of things needs to be rewritten.
Still a bug then.
You can pull the source for now: rbp2-source-4.2.3-2-osmc
