I’ve juste install the December update and then I’ve no more movies voices while my channels settings are set on 5.1.
I have to downgrade to 2.0, 2.1, 4.0 or 4.1 to have the voices.
It seems that channels which include central speaker does’nt work.
There are two threads on this issue today. Have a look and see if your situation is similar. If not, tell us about your system - receiver? TV? soundbar?
Actually the current fix resolves a multi-channel audio problem. As such, it’s likely your audio settings are not correctly configured and you were simply getting away with it before.
Before, we were getting complaints that 5.1 was being reduced to 2.0 with some amplifiers so it was changed. Right now, people are having issues where the amplifier/soundbar is connected to the TV rather than direct to vero. We may possibly be able to cater for that case in future if some people can’t connect their equipment that way. This shouldn’t happen but there’s thousands of combinations of TV and amplifier out there.
What you were hearing before may not have been what was on the files you were playing but some up-mix.
