Nedd
15 September 2017 10:19
1
Hello i would like a hand on how to manage multiple remotes to use CEC or the Vero4k Remote.
i have an LG 55EF950 with a magic remote AN-MR600 but the CEC does only works for arrows,
my guess is i should use logviewer to see what does CEC transmits to the Vero (i need to map select back and an other button for home and info)
but if i change kemap will it affect the Vero’s remote ? should i have 2 keymaps ? one for each remotes ?
thanks
LG CEC implementation is very limited, quite unlikely you get any more keys out of it.
A keymap is based on keys = action. So as I assume you want same action for same key not a problem and the key codes would be different anyhow otherwise it would work already
Nedd
15 September 2017 22:36
3
ok i tried to debug log the cec commands, but it is still gibberish :
00:34:24.229 T:3977712624 DEBUG: CecLogMessage - >> 01:89:01
00:34:24.229 T:3977712624 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): vendor command (89)
00:34:24.229 T:3977712624 DEBUG: CecLogMessage - << 10:89:02:05
00:34:24.382 T:3977712624 DEBUG: CecLogMessage - SL initialised
00:34:24.502 T:3977712624 DEBUG: CecLogMessage - >> 01:46
00:34:24.503 T:3977712624 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): give osd name (46)
00:34:24.503 T:3977712624 DEBUG: CecLogMessage - << Recorder 1 (1) -> TV (0): OSD name 'Kodi'
00:34:24.503 T:3977712624 DEBUG: CecLogMessage - << 10:47:4b:6f:64:69
00:34:24.759 T:3977712624 DEBUG: CecLogMessage - >> 01:89:01
00:34:24.759 T:3977712624 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): vendor command (89)
00:34:24.760 T:3977712624 DEBUG: CecLogMessage - << 10:89:02:05
00:34:24.912 T:3977712624 DEBUG: CecLogMessage - SL initialised
00:34:24.943 T:3977712624 DEBUG: CecLogMessage - >> 01:46
00:34:24.944 T:3977712624 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): give osd name (46)
00:34:24.944 T:3977712624 DEBUG: CecLogMessage - << Recorder 1 (1) -> TV (0): OSD name 'Kodi'
00:34:24.944 T:3977712624 DEBUG: CecLogMessage - << 10:47:4b:6f:64:69
00:34:25.152 T:3977712624 DEBUG: CecLogMessage - >> 01
00:34:25.152 T:3977712624 DEBUG: CecLogMessage - << POLL: TV (0) -> Recorder 1 (1)
00:34:25.289 T:3977712624 DEBUG: CecLogMessage - >> 01:89:01
00:34:25.289 T:3977712624 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): vendor command (89)
00:34:25.289 T:3977712624 DEBUG: CecLogMessage - << 10:89:02:05
00:34:25.442 T:3977712624 DEBUG: CecLogMessage - SL initialised
00:34:25.473 T:3977712624 DEBUG: CecLogMessage - >> 01:46
00:34:25.473 T:3977712624 DEBUG: CecLogMessage - << Recorder 1 (1) -> TV (0): OSD name 'Kodi'
00:34:25.473 T:3977712624 DEBUG: CecLogMessage - << 10:47:4b:6f:64:69
00:34:25.473 T:3977712624 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): give osd name (46)
00:34:25.841 T:3977712624 DEBUG: CecLogMessage - >> 01:89:01
00:34:25.841 T:3977712624 DEBUG: CecLogMessage - << 10:89:02:05
00:34:25.841 T:3977712624 DEBUG: CecLogMessage - >> TV (0) -> Recorder 1 (1): vendor command (89)
00:34:25.992 T:3977712624 DEBUG: CecLogMessage - SL initialised
