just curious , I check it. It seems not possible to disable it.
Playing albums now I get annoying duplicates in the library, and “Play” does not just that: play.
How to remove that “feature” ?
From the homescreen go into the music section then bring up the side/slide-out menu and uncheck the “Party Mode” checkbox. To bring up this menu on most skins view modes you just need to keep navigating in one of the directions till it pops up (most often left but would be up or down if the view is set to something side scrolling). If your using an OSMC remote you can just hold down (long-press) the menu button and that will make it pop up.
already tried this of course. Clicking on “Party Mode” starts some list,
probably compiled when I tried to play an album and just got the titles listed w/o playing a nothing.
the check left to “Party mode” seems always unchecked. It doesn’t toggle on click.
The party mode generates a playlist and you must be still playing the playlist. Are you saying that if you navigate to and play something from the Music>Artists or Music>Albums section it plays the party mode playlist instead of what you just told it to play?
nothing playing:
trying to play an album, will just show the record titles of that album one by one and no play.
Clicking on “Party mode” will start playing some list, presumably out of he albums I tried to play so far.
I don’t need this feature at all. I just wanted to check what happens.
Now I want to clear this mess and never touch it again ;(
I think that has no relation to the party mode but the source of the music files is not available anymore. Did you change any location of the music files before?
right :))
”Party mode” was incidentally set as a problem started to have effect.
I did change the Services > NFS Client to Protocol Version: 4 just before.
This because I thought the new Synology NAS would have got updated in this respect, seems not.
After reset the Protocol to Version 3, the files become available again.
Appreciate your hint ^B
