Hi everyone, I’ve been using the Grid Kodi skin, which I like a lot, but I cannot find My OSMC in the menus to go about updating my Vero4k. Is this an issue with the skin?
It should be under addons. If not then it’s a skin issue.
You can login via ssh and update manually:
sudo apt-get update
sudo apt-get dist-upgrade
Thank you for pointing out where to find it, it is indeed there
