Myosmc Backup failure
I’ve just reloaded my system from scratch and now when I try to do a backup using myosmc it fails, it just writes about 600kb (all the old ones were about 400Mb). If I use the backup from the osmc repository it works ok.
logs at https://paste.osmc.tv/omafuhazir
How can I get it to work without having to reload everything?
Are you trying to backup to a network share?
I can’t see why it fails from the log, but it it does seems to be having issues connecting to your mysql database:
2020-04-20 19:39:08.949 T:3962110688   ERROR: Unable to open database: MyMusic72 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.958 T:3962110688   ERROR: Unable to open database: MyMusic71 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.961 T:3962110688   ERROR: Unable to open database: MyMusic70 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.967 T:3962110688   ERROR: Unable to open database: MyMusic69 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.969 T:3962110688   ERROR: Unable to open database: MyMusic68 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.972 T:3962110688   ERROR: Unable to open database: MyMusic67 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.975 T:3962110688   ERROR: Unable to open database: MyMusic66 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.980 T:3962110688   ERROR: Unable to open database: MyMusic65 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.985 T:3962110688   ERROR: Unable to open database: MyMusic64 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.993 T:3962110688   ERROR: Unable to open database: MyMusic63 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.997 T:3962110688   ERROR: Unable to open database: MyMusic62 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:08.999 T:3962110688   ERROR: Unable to open database: MyMusic61 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.005 T:3962110688   ERROR: Unable to open database: MyMusic60 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.008 T:3962110688   ERROR: Unable to open database: MyMusic59 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.010 T:3962110688   ERROR: Unable to open database: MyMusic58 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.015 T:3962110688   ERROR: Unable to open database: MyMusic57 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.018 T:3962110688   ERROR: Unable to open database: MyMusic56 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.020 T:3962110688   ERROR: Unable to open database: MyMusic55 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.024 T:3962110688   ERROR: Unable to open database: MyMusic54 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.028 T:3962110688   ERROR: Unable to open database: MyMusic53 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.032 T:3962110688   ERROR: Unable to open database: MyMusic52 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.035 T:3962110688   ERROR: Unable to open database: MyMusic51 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.037 T:3962110688   ERROR: Unable to open database: MyMusic50 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.042 T:3962110688   ERROR: Unable to open database: MyMusic49 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.044 T:3962110688   ERROR: Unable to open database: MyMusic48 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.048 T:3962110688   ERROR: Unable to open database: MyMusic47 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.051 T:3962110688   ERROR: Unable to open database: MyMusic46 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.053 T:3962110688   ERROR: Unable to open database: MyMusic45 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.055 T:3962110688   ERROR: Unable to open database: MyMusic44 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.058 T:3962110688   ERROR: Unable to open database: MyMusic43 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.060 T:3962110688   ERROR: Unable to open database: MyMusic42 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.064 T:3962110688   ERROR: Unable to open database: MyMusic41 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.068 T:3962110688   ERROR: Unable to open database: MyMusic40 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.073 T:3962110688   ERROR: Unable to open database: MyMusic39 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.075 T:3962110688   ERROR: Unable to open database: MyMusic38 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.079 T:3962110688   ERROR: Unable to open database: MyMusic37 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.081 T:3962110688   ERROR: Unable to open database: MyMusic36 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.084 T:3962110688   ERROR: Unable to open database: MyMusic35 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.087 T:3962110688   ERROR: Unable to open database: MyMusic34 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.090 T:3962110688   ERROR: Unable to open database: MyMusic33 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.092 T:3962110688   ERROR: Unable to open database: MyMusic32 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.095 T:3962110688   ERROR: Unable to open database: MyMusic72 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.095 T:3962110688   ERROR: Unable to create new database
2020-04-20 19:39:09.098 T:3962110688   ERROR: Unable to open database: MyVideos116 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.101 T:3962110688   ERROR: Unable to open database: MyVideos115 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.105 T:3962110688   ERROR: Unable to open database: MyVideos114 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.108 T:3962110688   ERROR: Unable to open database: MyVideos113 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.111 T:3962110688   ERROR: Unable to open database: MyVideos112 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.113 T:3962110688   ERROR: Unable to open database: MyVideos111 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.119 T:3962110688   ERROR: Unable to open database: MyVideos110 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.121 T:3962110688   ERROR: Unable to open database: MyVideos109 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.123 T:3962110688   ERROR: Unable to open database: MyVideos108 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.127 T:3962110688   ERROR: Unable to open database: MyVideos107 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.131 T:3962110688   ERROR: Unable to open database: MyVideos106 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.134 T:3962110688   ERROR: Unable to open database: MyVideos105 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.139 T:3962110688   ERROR: Unable to open database: MyVideos104 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.143 T:3962110688   ERROR: Unable to open database: MyVideos103 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.147 T:3962110688   ERROR: Unable to open database: MyVideos102 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.149 T:3962110688   ERROR: Unable to open database: MyVideos101 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.152 T:3962110688   ERROR: Unable to open database: MyVideos100 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.155 T:3962110688   ERROR: Unable to open database: MyVideos99 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.158 T:3962110688   ERROR: Unable to open database: MyVideos98 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.160 T:3962110688   ERROR: Unable to open database: MyVideos97 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.163 T:3962110688   ERROR: Unable to open database: MyVideos96 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.168 T:3962110688   ERROR: Unable to open database: MyVideos95 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.173 T:3962110688   ERROR: Unable to open database: MyVideos94 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.178 T:3962110688   ERROR: Unable to open database: MyVideos93 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.180 T:3962110688   ERROR: Unable to open database: MyVideos92 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.182 T:3962110688   ERROR: Unable to open database: MyVideos91 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.185 T:3962110688   ERROR: Unable to open database: MyVideos90 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.189 T:3962110688   ERROR: Unable to open database: MyVideos89 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.192 T:3962110688   ERROR: Unable to open database: MyVideos88 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.194 T:3962110688   ERROR: Unable to open database: MyVideos87 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.199 T:3962110688   ERROR: Unable to open database: MyVideos86 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.201 T:3962110688   ERROR: Unable to open database: MyVideos85 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.204 T:3962110688   ERROR: Unable to open database: MyVideos84 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.207 T:3962110688   ERROR: Unable to open database: MyVideos83 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.210 T:3962110688   ERROR: Unable to open database: MyVideos82 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.212 T:3962110688   ERROR: Unable to open database: MyVideos81 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.215 T:3962110688   ERROR: Unable to open database: MyVideos80 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.218 T:3962110688   ERROR: Unable to open database: MyVideos79 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.220 T:3962110688   ERROR: Unable to open database: MyVideos78 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.223 T:3962110688   ERROR: Unable to open database: MyVideos77 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.228 T:3962110688   ERROR: Unable to open database: MyVideos76 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.231 T:3962110688   ERROR: Unable to open database: MyVideos75 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.235 T:3962110688   ERROR: Unable to open database: MyVideos116 [2003](Can't connect to MySQL server on '192.168.1.9' (111 "Connection refused"))
2020-04-20 19:39:09.235 T:3962110688   ERROR: Unable to create new database
It looks like you need to fix your network config. If you are backing up to a network share, fixing the config; will probably fix the backup as well.
Thanks Tom.
Hi Tom,
No its backing up to a local disk, but the errors seemed to be related to the music database which I have now removed, but still the same.
new logs at https://paste.osmc.tv/ukuwavavow.
Have removed mysql altogether as I don’t think I need it. I only want to read and write files to a common folder from either vero, which I can do with shares. But myosmc backup still not working.
Does backup over write the osmc system? As it seems to have occurred since re formatting the vero. Thinking I could do that again and restore the osmc repository backup which did work. I prefer the myosmc backup as I can restore individual items, so would like to get it working.
Stupid Question here, but the logs show attempt to run a backup?
I ask can’t see one failing.
Where are they being backed up to?
Thanks Tom.
They are backed up to a local risk called bedroom/backup.
I tried a myosmc backup and then grabbed logs.
What are you expecting to be in the backup? Does it actual say its failed?
Have you tried backing up to a different location?
Thanks Tom.
No it doesn’t say fail, it goes to 100% but exceedingly quick, like a couple of seconds. Also it is extremely small file, about 400kb instead of 400mb.
And my other question:
Not yet. Will do tomorrow.
Hi Tom,
My Bad, it was backing up ok, but the “back up apps” wasn’t ticked so it was only the system files that got backed up. Ticked apps and it is a bigger file, about 150mb. Still smaller than the originals but there are not as many apps and rubbish files.
Thanks for your help.
Just wondering now wether I need mysql setup or leave it disabled.
