Hi, quick question.
Is MyOSMC enable/disable wireless toggle equivalent to adding “dtoverlay=pi3-disable-wifi” to the config.txt?
Thanks.
Hi, quick question.
Thanks.
No that setting will not impact config.txt, that part you need to do via Raspberry section
Yes I am aware of that, but functionally, do they do the same thing?
No, they disable wifi on different levels
Ok, that’s what I was curious about.
I will resort to disabling it in the config.txt since I don’t need wireless.
