I updated a skin to 1080p and since then the my osmc settings looks like this. Is the resolution of osmc settings hardcoded at 720p and if so is there way to change it. Displays fine on 720p skins.
Heres debug log
Heres debug log
Which skin? Have you rebooted since? Can you try another 1080 skin as well?
Hi karnage thanks for reply.
I’m using aeon mq 6 skin. I updated it to 1080i. I tried the titan skin and its 1080i and it displays fine so its a skin issue I believe. The osmc settings pictures are displaying fine think the text is font too large.
Would you know what XML file the osmc settings relate too or is it skin specific.
