EDIT: The power in my house sometimes breaks so I’ve installed 2 years ago the Network UPS Tools package (NUT) on my PRI which works until now. I need a hand to fix the issues (I have had a stroke last summer and I must say I am very diminished and unable to do this by myself). I’ve checked the scripts (founded here) andnothing has change. So if a gooder can help… Thanks in advance.
Hi all
got an issue with my Eaton UPS which suddenly lost connection with my Raspberry.
Does someone has an idea of what happened?
Some errors (Failures) too can be seen on the log…
Here: kopipefaju
Jun 24 18:02:13 osmc upsmon[425]: Login on UPS [eaton@localhost] failed - got [ERR ACCESS-DENIED]
You probably should contact Eaton support. From that error it looks like it’s refusing the connection. Did you have to install anything to get the Pi to work with the UPS? Maybe try removing the package and re-installing it.
Jun 24 18:02:13 osmc rc.local[309]: curl: (60) SSL certificate problem: certificate has expired
This looks like a possible cause. Have a look at /etc/rc.local and see what SSL certificate it’s referring to. The instructions for NUT at 9. NUT daisychain support notes do talk about generating a key/certificate pair, so it might be related to that:
Use the following command to create the certificate:
