Need help while upgrading
Hi all!
I’ve just run “sudo apt-get update” and “sudo apt-get dist-upgrade” and here there is the error I’ve got:
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Setting up rbp2-image-4.4.16-4-osmc (4) …
Running depmod.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.16-4-osmc /boot/vmlinuz-4.4.16-4-osmc
run-parts: executing /etc/kernel/postinst.d/inform-updater 4.4.16-4-osmc /boot/vmlinuz-4.4.16-4-osmc
run-parts: executing /etc/kernel/postinst.d/process-vmlinuz-rbp 4.4.16-4-osmc /boot/vmlinuz-4.4.16-4-osmc
find: /boot/dtb-4.4.16-4-osmc/overlays/': No such file or directory find: /boot/dtb-4.4.16-4-osmc/overlays/’: No such file or directory
Aborting due to one or more missing device tree overlays.
run-parts: /etc/kernel/postinst.d/process-vmlinuz-rbp exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/rbp2-image-4.4.16-4-osmc.postinst line 391.
dpkg: error processing package rbp2-image-4.4.16-4-osmc (–configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of rbp2-kernel-osmc:
rbp2-kernel-osmc depends on rbp2-image-4.4.16-4-osmc; however:
Package rbp2-image-4.4.16-4-osmc is not configured yet.
dpkg: error processing package rbp2-kernel-osmc (–configure):
dependency problems - leaving unconfigured
rbp2-kernel-osmc
Any idea?
Up! :frowning:
