I installed Netflix today on my Vero4K +.
Works, but unfortunately I can’t play UHD movies in resolutions higher than 720p. Even 1080p jerks and loses sound. During such recovery, the CPU usage reaches 100% and hence these problems. Are our Vero4K + too weak for higher resolutions in Netflix or do I have something wrong configured?
Since the current Netflix solution available for OSMC is software decoding, the cpu is the limiting factor on both pi2/3 and vero4-series.
Thank you for the quick reply. That’s sad information. Then I have to think about buying new equipment for Netflix.
