I am using OSMC 2018.08-2 on PI 3B.
in My OSMC / Network, I have experienced an handled exeception while trying to connect to a wireless Network protected by passphrase. Each time, I select a given available closed WIFI network, the GUI shows “Networking add-on | unhandled exception” and does launch the screen to enter the WIFI passphrase. As a result, It is impossible to connect the OSMC to any wireless network.
After some investigation, it seems that this GUI exception is a consequence of not having any Bluetooth device enabled in the PI. It means that if the My OSMC / Network menu does not contain any Bluetooth “category”, the exception will raise.
I have experiened this exception when disabling on purpose the internal BT device (dtoverlay=pi3-disable-bt in conf.txt) and without have plugged the external OSMC approved BT device. As a result, no BT category was present in my OSMC / network and the error poped up. When re-enabling the internal device OR plugging the external BT device at startup OR both, the BT category was present and no exception were raised and the screen inviting me to enter the passphrase was properly showed and I could connect to the WIFI network.
Has anyone experienced similar behaviour while playing around with BT devices ?
It looks like a bug but better double-check with OSMC experienced users…
I have copied/pasted here the kodi debug lines linked to this networking add-on exception
1st Attempt
23:38:15.298 T:1645888256 DEBUG: Attempting connection to /net/connman/service/wifi_b827ebd2715d_486f74656c20416e7469717565203635_managed_psk
23:38:15.323 T:1645888256 DEBUG: Unhandled Exception thrown in Networking GUI
File “/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/networking_gui.py”, line 390, in onClick
self.handle_wireless_selection(controlID)
File “/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/networking_gui.py”, line 1205, in handle_wireless_selection
self.handle_selected_wireless_network()
File “/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/networking_gui.py”, line 1284, in handle_selected_wireless_network
self.connect_to_wifi(ssid, encrypted)
File “/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/networking_gui.py”, line 1357, in connect_to_wifi
connection_status = osmc_network.wifi_connect(path, None, hiddenssid, script_base_path)
File “/usr/share/kodi/addons/script.module.osmcsetting.networking/resources/lib/osmc_network.py”, line 330, in wifi_connect
service.Connect(timeout=15000)
File “/usr/lib/python2.7/dist-packages/dbus/proxies.py”, line 70, in call
return self._proxy_method(*args, **keywords)
File “/usr/lib/python2.7/dist-packages/dbus/proxies.py”, line 145, in call
**keywords)
File “/usr/lib/python2.7/dist-packages/dbus/connection.py”, line 651, in call_blocking
message, timeout)
File “/usr/lib/python2.7/dist-packages/dbus/exceptions.py”, line 47, in init
if name is not None or getattr(self, ‘_dbus_error_name’, None) is None:
TypeError: ‘NoneType’ object is not callable
2nd Attempt
23:40:11.481 T:1645888256 DEBUG: Attempting connection to /net/connman/service/wifi_b827ebd2715d_486f74656c20416e7469717565203635_managed_psk
23:40:11.487 T:1645888256 DEBUG: Unhandled Exception thrown in Networking GUI
**keywords)
message, timeout)
