New Vero V Stutter Issue
Just got a Vero V and updated it to latest version and set up Kodi.
I enabled Adjust display refresh rate and added resolutions to my whitelist. using passthrough audio to my AVR.
This is same set-up as my RPi 5 running LE.
However I am getting stuttering on all 24 fps videos.
logs: https://paste.osmc.tv/cicoxojopu
Any help?
Yes. Don’t enable sync framerate.
That would been it plays back 24fps content at 60 which would be worse.
This was fine on my Pi
I dont mean sync playback to display that was typo. I meant Adjust display refresh rate.
Ah! I don’t know then. I can see lots of errors in your log but not sure what to suggest. Was the scraper running on your library when you tried to play those files?
nope
I use the local nfo files instead of online
If you haven’t spent much time setting it up, you could try reinstalling. Or wait to see if anyone else has an idea about this.
Your Vero V sees the available resolutions your Denon AVR tells the device … and not the actual available resolutions of the TV.
I know from bitter experience that what I’m about to suggest might cause a lot of work: For testing purposes, could you connect the Vero directly to your TV, delete the whitelisting configuration for the resolutions beforehand, and then play the video again?
At least that way you could rule out/isolate the AVR as the cause of the problem.
Another log set from this configuration, and playing one of these videos, would also be helpful.
Will try that and get back to you but as I said this was all working on my Pi without issues on Kodi.
Was playing via AVR and had whitelisted same resolutions.
Suggest to upload a log from the Pi so we can see as well.
So I reset it and set it up again and stutter is gone.
Strange. Anyway thanks all
