I’ve recently transitioned to the Vero 4k and am experiencing a very slow UI when transitioning between ‘Movies’ and ‘TV Shows’. It often takes nearly 30 seconds before any data appears on the screen. Additionally (and this may not be related), I experience a significant delay between selecting ‘Update Library’ and when the scanning actually starts.
Any ideas what to look for in the logs?
NFS shares
Rapier skin
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Tested a few others and little to no lag. @MidnightWatcher since it sounds like you’re a Rapier fan as well, any suggestions on other skins that you’ve found to be similar?
I’ve just gotten used to it. Been using Raper since I got my Vero 4K and was never able to determine the issue.
I was a fan of the Aeon Madnox skin as I like fanart and clearlogos etc (that skin is a BEAST though), and found Rapier to be the closest - I’d also be on board if there are similar skins with perhaps better performance.
I’ve never found anything I like as much as Rapier, so I’ve never bothered to switch. The only other skin I like is Bello but it’s minimalist and I don’t think it supports clear logos, which are a must for me.
I would agree.
I can’t recall if I ever reported this the Rapier skin thread on the Kodi forums, I think so but would have to doublecheck. If this is a specific issue with Rapier AND Vero/OSMC maybe it’s worth bringing up to Gade the skinner since we have multiple users with the same issue?
Skin link on Kodi forums: https://forum.kodi.tv/forumdisplay.php?fid=120
I’ll see if can get to that later tonight or tomorrow if no one beats me to it.
Apologies for the thread resurrection, but the Rapier skin developer replied to our posts about this on the Kodi forums.
He’s re-writing all views, doing some optimizing, and needs testers for Kodi 19. I told him I’d post the request here as it may get more visibility to the Vero crowd.
