No bluetooth
Hello
the config panel of bluetooth as disappear.
http://paste.osmc.io/qafucotoro
And my osmc is very slow.
Regards
Which Bluetooth adapter do you have?
What are you doing when OSMC is slow?
Hello sam
I wrote about the application “my osmc” .It takes 30 s. to quit it or to navigate in the left menu.
The bluetooth adapter is include in the vero 2 device ?
The Vero 2 does not have built in bluetooth.
Hello
You are right.I confused with the vero 1st generation.
But the navigation in the “my OSMC” is too slow there is a big latency.
:confused:
Ok.
We had some reports of slow My OSMC but I couldn’t replicate this. Will check again soon
This appears to affect other platforms, so it is a software problem that we endeavour to fix shortly
Is there an easy way for me to replicate this slow behaviour so I can see what’s going on?
As Sam wrote there are a few mentions about slowness but nothing concrete so far.
Looks like you are connected via Ethernet, does it help if you disable wireless in MyOSMC (may need to reboot afterwards). Also as you mentioned Bluetooth, are you using (or have you used) any Bluetooth dongle? Have you installed any software packages for that?
Is the slowness of MyOSMC something that only recently happened?
hello
I’ve made a test without network ,nothing change.
My OSMC is slow since i’ve received
I haven’t any bluetooth dongle installed to Vero2
Many thanks, we are still trying to replicate it. Will keep you posted.
Just to check when you said “without network” I assume you ment with wireless disabled as I asked,or?
