I’ve had Pi 2 and recently bought Pi 3 and have used the existing card (from the Pi 2) for that new board.
Everything was updated and I did update+dist-upgrade after the “migration” to the new board, yet onboard BT or WiFi are not recognized.
Programs -> OSMC Settings -> Network
shows only Wired.
osmc@osmc ~ $ hciconfig
osmc@osmc ~ $ hcitool dev
Devices:
osmc@osmc ~ $
bluetoothctl works, but no agent can be used:
[bluetooth]# default-agent
No agent is registered
I’ve used BT with a dongle on Pi 2 w/o a problem.
Connman:
osmc@osmc ~ $ sudo cat /var/lib/connman/settings
[global]
OfflineMode=false
[Wired]
Enable=true
Tethering=false
[Bluetooth]
Enable=true
Tethering=false
/boot/config.txt:
gpu_mem_1024=320
sdtv_mode=2
device_tree=bcm2709-rpi-2-b.dtb
dtparam=i2c1=on
dtparam=spi=on
#core_freq=450
start_x=1
sdtv_aspect=1
disable_overscan=1
#arm_freq=900
#sdram_freq=450
hdmi_ignore_cec_init=1
#hdmi_edid_file=1
#hdmi_force_hotplug=1
dtparam=i2c_arm=on
device_tree_param=i2c_arm=on
gpu_mem_256=112
gpu_mem_512=144
arm_freq=850
core_freq=375
Ideas?
