I just installed osmc via osmc-installer. Everything went fine - I had a fresh install of osmc, with no libraries or paths. When I tried to restore settings from a backup I had on my lan (via NFS) I did: My OSMC->Updates->Manual Controls->Restore Backup. But when I tried to browse for the backups, there was no option to browse any networks - just Home Folder and Root Folder. The network connection is fine, but anywhere I try to browse for a path, there is no network option (ie, NFS, SMB, etc). There used to be, though.
DId something change, or did I just miss something?
TIA
ken
