No response from support emails- Vero V remote double presses
I purchased a Vero V on 3 January 2026 (order #82401). The supplied remote developed a problem where a single button press is registered twice.
I’ve tried replacing the battery, re-pairing the remote and checking for possible USB 3 interference, but the problem persists.
I emailed support@osmc.tv on 7 September and followed up on 6 October, but haven’t received a response to either message.
Is this email address still the recommended way to obtain support for a potentially faulty remote? Has anyone else had difficulty getting a response?
I’d appreciate some advice on how best to proceed, including whether the remote or receiver might need replacing.
Can you let me know your ticket number so I can check this? Alternatively can you confirm that your GMail address you’ve used here is the correct one to contact you on
I have found and updated the ticket. Please let me know if not received.
