Just using the new 4k+ and applied the hot fix for the hdr banding, immediately lost output and can’t get it back. If I hard reset it then I get some of the startup stuff then nothing.
Can you ssh in, details can be found here:
If not I would consider a reinstall:
Thanks Tom.
That hotfix has now been incorporated into the release, so is unnecessary.
If unfamiliar with command line, I’d recommend reinstalling OSMC as it will get you up and running again quickly
