• frequent “no signal” on TV during playback. (green screen with message.) Usually file starts playing for a second or two and then drops out. Usually, rebooting VeroV resolves the issue – for one playback – and then happens again on the next file.
here’s a debug log. In this case playing:
Secrets.We.Keep.S01E03.1080p.HEVC.x265-MeGusta.mkv
if latter problem were rare it wouldn’t be a big deal to reboot, but it happens very frequently.
message on TV, green screen: No signal. Check the external input or select another input using the INPUT button.
as for full debug log, what do you mean? that was a debug log wasn’t it? if you mean starting from fresh boot, that wouldn’t work, because the problem doesn’t happen after a fresh boot.
Run the following command to add the staging repository: echo 'deb http://apt.osmc.tv bullseye-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command: sudo rm /etc/apt/sources.list.d/osmc-devel.list.
reproduce the issue
I installed the staging updated and will report back. feel free to PM to remind me after a few days.
with this i’m confused. did you not see the debug log I posted in top post? I know how to turn on debug logging. I also mentioned that I cannot reliably reproduce the issue immediately after a reboot. nevertheless i will try, and upload the full log set (which is, I see, quite different than posting a debug log.)
First play after reboot works. Subsequent plays, no signal.
Also, the update to the staging version did not work. Received error messages that said report in forum. [edit: tried apt-get update (as above) again, and it seems to have worked, although it asked about which version of the openssh-server to install. chose “package maintainer’s version”]
