After every kodi restart I have problems with the sound. To fix that I have the following workaround:
change the audio output from the TV to TV speaker
restart kodi
change the audio output from the TV to HDMI CEC
Audio is working again via HDMI on my soundbar
During the problem I see the following errors in the log:
2026-05-12 15:23:08.108 T:8845 info : CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2026-05-12 15:23:08.108 T:8845 info : CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE3
2026-05-12 15:23:08.112 T:8845 warning : CAESinkAlsa::InitializeHW - Using default alsa values - set failed
2026-05-12 15:23:08.114 T:8845 info : CAESinkALSA::Initialize - Attempting to open device “default”
2026-05-12 15:23:08.119 T:8845 info : CAESinkALSA::Initialize - Opened device “default”
Any ideas how to get this fixed and audio is still working after restart/reboot? (Raspberry Pi 4)
Fabian
Can nobody help me to get this fixed?
If needed I can provide more infos.
reproduce the issue
Hi Tom,
thanks for your reply. I did the following:
- enable debug log
- rebooted the device twice time
- changed the audio output on the TV from HDMI to TV speaker
- restarted mediacenter
- changed the audio output on the TV from TV speaker to HDMI
- audio over HDMI is working
- Uploaded the logs
https://paste.osmc.tv/denutezasa
Would be great if we can find a solution for this problem
Fabian
Have you tried a complete shutdown and power off?
I suggest after shutting it down, unplugging the pi, tv and soundbar from the mains and leave without power for 10 minutes. The power drain should make everything reset and work as expected.
Regards Tom.
Hi Tom,
this also solved not the problem.
BUT: I played a bit with the TV audio settings. After disabling eARC I can reboot the Pi / restart mediacenter and I don‘t have any audio problems any more.
If somebody run into the same issue look for eARC on your TV and disable this feature.
Thanks and regards
Fabian
Glad to hear its sorted. But thisdepends on whether soundbar supports eARC.
Regards Tom.
