No Sound anymore
i have the Pi3 since 6 monthes. It works great since one month. i don’t have sound anymore… Help me
Try to explain a bit more, e.g. which sound output are you using and have you tried to change the volume in Kodi? Also provide some logs.
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us help you.
If you have a red circle with a speaker in the middle and a slash through it in the upper right corner the sound is muted if you have a keyboard hooked up to it hit the f10 button
Should be F8
http://kodi.wiki/view/Keyboard_controls
F10 will work if you are muted or the volume is turned all the way down.
