Hi, When I connect this cable http://www.allekabels.nl/jack-kabel/4/1507/jack-tulp-kabel.html raspberry to my hifi technics has no sound. It is silent and with pops and a sound of a short circuit. I use this cable to connect a laptop with HiFi and everything works fine. I will add that when the headphones are connected to the raspberry pi the sound is. Is it the fault of osmc settings? I chose the settings “HDMI and analog” but it does not work.
That sounds weird!
Only ideas I have to this
- the case of the Pi prevents the jack to get fully inserted
- try again with having set Kodi’s sound volume muted/set to 0 and carefully increase the volume
That cable is a 3 pole for stereo sound only.
The (later) RPi models use a 4 pole jack to connect, so there is the possibility of all sorts of problem with mismatched connectors.
HTH
Derek
Ok, but the headphones they play have the same minijack like this laptop-hi-fi cable that does not play. so what’s the difference? ; (
Impossible to say without more information.
Might be how the connections are made, what depth the jack can be inserted …
Also, you haven’t mentioned which hardware you are using - original RPi with separate audio and video jacks or later RPi with one integrated audio and video jack.
Derek
jack was not put in full, my mistake. thanks for the suggestions
