No sound on files with AAC codec
Hi, i don’t know if the problem is since the may update because i don’t have seen this TV Show for a while but files with AAC audio codec i get the video but no audio signal.
here is a log of MediaInfo
http://paste.osmc.io/linayesiha.mel
Other Seasons that are using Dolby i have no problem, and i know all of them worked properly before but not sure if the problem is since may update or not.
How is your audio configured?
from vero2 with hdmi to a denon x1100w AVR.
Settings in kodi are dolby and dts enabled and passthrough is also enabled.
if i switch to internal audio from tv no problem.
I am not sure what you mean by this.
You may wish to enable AC3 transcoding.
yeah i have enabled ac3 encoding and dts, also enabled passthrough on vero2.
Can you produce a debug log which may give some insight?
I figured out why i got no sound on the named files… as i can’t see my AVR in the sound settings and no HDMI option i selected AML-M8AUDIO, Analog because i haven’t connected the vero2 to an optical output what i thought (s/pdif) was meant.
now i found in the forum that someone asked about not seeing his AVR and u told him to set to S/PDIF as it is passthrough, and i tried this. Now the files have sound :slight_smile:
Maybe i am not as technical as i should be :smiley:
so i can close this thread now.
Thanks for your help.
