I’m wanting to play some MKV video files. I am able to select the video file and play it, there is video, but no audio! Very frustrating… I am able to play the files no problem through my PS3.
I enabled logging while trying to play the file, the log can be found here:
https://paste.osmc.tv/alasuvogut
Does anyone know what the problem is and how I can fix it?
Thanks.
- Do you hear GUI sounds (navigation)?
- Have you unmuted OSMC?
- What is your adudio setting under “settings -> system -> audio” in terms of “Audio output device”, “output configuration” and “Allow Passthrough”
- Provide Mediainfo of the file you try to play
Please see the mediainfo section in How to submit a useful support request - General - OSMC
Hi @fzinken, thanks for responding.
Yes I hear GUI sounds (Navigation)
OSMC is not muted.
Audio settings are:
Audio Output Device = Pi:HDMI
Allow Passthrough = Off
The mediainfo of the file can be found here: http://paste.osmc.io/usimebedol.tex
Two initial observations:
- You appear to be playing mpeg2s without a hardware codec - I’m surprised it works.
- The mediainfo is for S01E20.mkv but in the log you appear to be playing S01E20.mkv_transcoded_to.mpg. Can you clarify?
It’s a bit difficult to see what’s going on. Better in future if you could reboot, just try to play one problem file then get the logs.
PS: this guy had to enable stereo upmix for a stereo audio track. Don’t know why but worth a try. After upgrade to Kodi17 AC3 stereo doesnt play
Apologies I should have mentioned this from the start, but didn’t think it was important. I am streaming the video from my PC to OSMC using Universal Media Server and UPnP. As a result I think that there may be some transcoding going on with Universal Media Server making the file available to OSMC…
I am away from home at the moment, but expect to be back this weekend, I can try enabling stereo upmix to see whether it has any impact…
About the mediainfo of mkv:
Nothings to strange… it’s a normal x264 codec for video and AC3 for audio.
It’s also use High@3.1 for profile encoder and it’s the best for compatibility also on “old” device.
Normally the Pi2 and Pi3 can reproduce this file whitout any problems… i can suggest to try to reproduce it from a usb device connect directly to Pi2 and not by a network sharing service and see what’s append.
