I have a new Vero V. Whenever I power everything off for the night (just as an example; I’ve also seen the same behavior if only an hour has passed) when I power things up again, the Vero V doesn’t output video. If I login to the web UI, it says a screensaver (aerial) is playing which I can pause, unpause, so it seems the unit isn’t hung, but no matter what I press on the remote the Vero doesn’t seem to output video until I pull the power and it starts working immediately as it boots up. I have the screensaver set to 5 minutes and all suspend features including turn off display are disabled. I opened a support ticket as well but wasn’t sure if I should post here too as it’s my first issue.
GUI Resolution: 3840x2160 @ 60p
<setting id="lookandfeel.skin">skin.embuary-matrix</setting>
<setting id="screensaver.mode">screensaver.atv4</setting>
Suggestion: Reset these settings the to defaults for tests.
- Don’t use other resolutions higher than1920x1080 for the GUI!!! Higher resolution can create issues with sound and behaviour. Playback resolutions aren’t affected by this setting.
- Use the OSMC skin.
- Use the Dim screensaver.
- Enable debug logs, see below
If this also create this issue, create new logs with these settings. Otherwise make changes step-by-step, so you know, who is guilty.
reproduce the issue
upload the log set (all configs and logs!) either using the
