No wake up
My VeroV does not wake up with the remote, I select sleep on the previous night, the blue led is lit but it will not respond to the remote. If I use Kore and select reboot it awakes or I can remove the DC plug and plug back in, this is very strange behaviour!
Even stranger, it just started playing a film after 15 mins of blank screen and no input from me, I was typing the post above🙄
Going to need to see some logs via ssh to work out what’s going on
I tried to do that before, I use windows 7, I downloaded various files but couldn’t not get SSH working. I have used lateral thinking, I only use the V for playing my HDD files, the HDDs are on a WiFi socket, I put the V on there also, it now powers up with the drives, solved!
