Thanks Sam, much appreciated, Would it be possible to start again, I would be happy to reset my 6month old box, In that 6months i’m not sure what i have done, I know it’s not a lot as i have been mainly bewildered and confused since the purchase…thanks again
Yes, you can start fresh. Do you have a micro SD card handy?
Do you use Windows or Mac?
Would a USB stick suffice, Coincidentally i am waiting for sd cards to arrive in the post…
I use windows pc
USBs generally work, but failing that micro SD will definitely work.
Go to Download - OSMC.
Grab the Windows installer.
Select Vero 4K and follow the steps. SD card etc will be greyed out so ignore and just click next.
Put the USB in and start the device and OSMC will reinstall.
When this is done, follow OpenVPN for Kodi to install this VPN add-on. You can the get NordVPN going just fine.
Provided you haven’t installed LibreELEC to internal storage, you should be alright.
Let me know how you get on.
Thanks Sam, On it, I shall get back to you “soon” either way
