i have some trouble to install OSM on NFS server
here are my exposts
/DataVolume/shares/osmc 192.168.25.20(rw,no-root_squash,sync,no_subtree_check,insecure)
install done without error but on boot i got bad smile bootloop
here are log
https://paste.osmc.tv/iqikedovog
could you help me to troubleshoot?
regards
BF
We need grab-logs -A
(capital A).
blairfancy:
Is this a copy/paste?
It should be no_root_squash
Remove insecure
. It’s not necessary.
Non it ils not a copy paste paramètre on exports bas right syntaxe.
Well, perhaps you could copy/paste it here.
Nothing stands out. You have no system journal, which is a significant problem but it’s not clear why not.
I also see that your NFS partition is 100% full. Try to free some space and see if that helps.
As you can see partition has 5go free i think it is enouth for raspi
i got lots of error when i run command grab-logs -A.
when ssh to osmc it complaint about /etc/sudoers: Permission denied
probably hint about the issue
here are extract of exports:
/DataVolume/shares/osmc 192.168.25.20(rw,no_root_squash,sync,no_subtree_check,insecure)
Which NFS server are you using ?
Are you using a system with proper ACLs? Can you show your exports?
I use a Mybooklive nas from WD. Exports already given previously:
ls -l on nas for osmc folder:
drwxr-xr-x 22 root root 65536 Mar 29 12:32 osmc
In complement DataVolume is a partition in EXT4 format
Any advice to solve my issue?
Not without proper logs, no.
Try an NFS export from a Linux system if you are able.
blairfancy:
You are right installed OSMC on ubuntu share and it works properly. Now i need to dig on MyBookLive device to see what goes wrong.
