I’ve just upgraded my RPi3 set-up to a RPi4 and the latest OSMC
I’m having an issue with the two connected hard drives not spinning down
Here’s the information on the drives from hd-parm:
osmc@osmc:/dev$ sudo hdparm -I sda1
>sda1:
SG_IO: bad/missing sense data, sb[]: 70 00 05 00 00 00 00 0a 00 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ATA device, with non-removable media
Standards:
Likely used: 1
Configuration:
Logical max current
cylinders 0 0
heads 0 0
sectors/track 0 0
Logical/Physical Sector size: 512 bytes
device size with M = 1024*1024: 0 MBytes
device size with M = 1000*1000: 0 MBytes
cache/buffer size = unknown
Capabilities:
IORDY not likely
Cannot perform double-word IO
R/W multiple sector transfer: not supported
DMA: not supported
PIO: pio0
If I try and manually put the drive to sleep - this is what I get:
osmc@osmc:/dev$ sudo hdparm -Y sda1
sda1:
issuing sleep command
I’m using the exact same HDs that I was using with OSMC on my Pi 3 - which did spin down
