Pulled a new log with a reboot before. Same issue, skipping forward repeats all over (“previous line repeats x times”, altogether 298 times) until I press “back” which then throws me back to the gallery, because it reverts at the same speed. Extract:
08:44:17.034 T:4078957136 DEBUG: Activating window ID: 12005
08:44:17.035 T:4048651008 DEBUG: ActiveAE - start sync of audio stream
08:44:17.035 T:3560960768 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(-191838.580984)
08:44:17.037 T:4078957136 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
08:44:17.038 T:4078957136 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
08:44:17.038 T:4078957136 INFO: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY
08:44:17.055 T:4078957136 DEBUG: ------ Window Deinit (Custom_Cache_Progress.xml) ------
08:44:17.135 T:4048651008 DEBUG: ActiveAE::SyncStream - average error of 33.797789, start adjusting
08:44:17.135 T:4048651008 DEBUG: ActiveAE::SyncStream - average error 0.797789 below threshold of 30.000000
08:44:17.185 T:4078957136 DEBUG: CAMLCodec::SetVideo3dMode:mode3d(0x0)
08:44:17.185 T:4078957136 DEBUG: CAMLCodec::SetVideoRect:display(0,0,1920,1080)
08:44:17.185 T:4078957136 DEBUG: CAMLCodec::SetVideoRect:gui(0,0,1920,1080)
08:44:17.185 T:4078957136 DEBUG: CAMLCodec::SetVideoRect:m_dst_rect(58,33,1801,1013)
08:44:17.185 T:4078957136 DEBUG: CAMLCodec::SetVideoRect:dst_rect(58,33,1801,1013)
08:44:17.185 T:4078957136 DEBUG: CAMLCodec::SetVideoRect:m_stereo_mode(0)
08:44:17.185 T:4078957136 DEBUG: CAMLCodec::SetVideoRect:m_stereo_view(0)
08:44:17.282 T:4028625664 DEBUG: CEGLNativeTypeAmlogic: Detected HDMI switch
08:44:18.160 T:3534430976 DEBUG: CDVDClock::ErrorAdjust - CVideoPlayerAudio::OutputPacket - error:-28435.631210, adjusted:-28435.631210
08:44:19.588 T:3560960768 DEBUG: CPullupCorrection: detected pattern of length 1: 20000.00, frameduration: 20000.000000
08:44:21.701 T:4078957136 DEBUG: LIRC: Update - NEW at 70119:6a 0 KEY_RIGHT linux-input-layer (KEY_RIGHT)
08:44:21.701 T:4078957136 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is StepForward
08:44:21.703 T:4078957136 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
08:44:22.455 T:4078953216 DEBUG: CAnnouncementManager - Announcement: OnSeek from xbmc
08:44:22.455 T:4078953216 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnSeek
08:44:22.462 T:3794514688 DEBUG: CVideoPlayer::SetCaching - caching state 1
08:44:22.462 T:3794514688 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
08:44:22.462 T:3794514688 DEBUG: demuxer seek to: 15208.000000
08:44:22.462 T:3794514688 DEBUG: SeekTime - unknown position after seek
08:44:22.462 T:3794514688 DEBUG: demuxer seek to: 15208.000000, success
08:44:22.462 T:3794514688 DEBUG: CVideoPlayer::FlushBuffers - flushing buffers
08:44:22.470 T:3534430976 DEBUG: CDVDAudio::Pause - pausing audio stream
08:44:22.529 T:3836982016 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnSeek - data: {"item":{"id":1493,"type":"episode"},"player":{"playerid":1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":0,"seconds":10},"speed":1,"time":{"hours":0,"milliseconds":200,"minutes":0,"seconds":15}}}
08:44:22.585 T:4078957136 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is StepForward
08:44:22.682 T:3534430976 DEBUG: CDVDAudio::Flush - flush audio stream
08:44:22.683 T:3534430976 DEBUG: CDVDAudio::Pause - pausing audio stream
08:44:22.785 T:4078957136 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is StepForward
08:44:22.989 T:3560960768 DEBUG: Previous line repeats 1 times.
08:44:22.989 T:3560960768 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
08:44:23.185 T:4078957136 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is StepForward
08:44:23.465 T:3794514688 DEBUG: Previous line repeats 1 times.
08:44:23.465 T:3794514688 DEBUG: CDVDMsgGeneralSynchronize - global timeout
08:44:23.465 T:3794514688 DEBUG: CVideoPlayer::SetCaching - caching state 2
08:44:23.465 T:3794514688 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
08:44:23.467 T:3534430976 DEBUG: CDVDMsgGeneralSynchronize - global timeout
08:44:23.467 T:3534430976 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
08:44:23.467 T:3534430976 DEBUG: CDVDAudio::Pause - pausing audio stream
08:44:23.470 T:4078957136 DEBUG: ------ Window Init (Custom_Cache_Progress.xml) ------
08:44:23.472 T:4078957136 DEBUG: started alarm with name: iscachingtimer
08:44:23.474 T:3794514688 DEBUG: CVideoPlayer::HandleMessages - player started 1
08:44:23.586 T:4078957136 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is StepForward
08:44:24.006 T:3560960768 DEBUG: Previous line repeats 2 times.
08:44:24.006 T:3560960768 DEBUG: CAMLCodec::SetSpeed, speed(0)
08:44:24.006 T:3560960768 DEBUG: CAMLCodec::Reset
08:44:24.085 T:3560960768 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
08:44:24.085 T:3560960768 INFO: CVideoPlayerVideo - Stillframe left, switching to normal playback
08:44:24.185 T:4078957136 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is StepForward
08:44:24.388 T:3794514688 DEBUG: Previous line repeats 1 times.
08:44:24.388 T:3794514688 DEBUG: CVideoPlayer::HandleMessages - player started 2
08:44:24.388 T:3794514688 DEBUG: CVideoPlayer::SetCaching - caching state 3
08:44:24.388 T:3794514688 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
08:44:24.388 T:3794514688 DEBUG: CVideoPlayer::SetCaching - caching state 0
08:44:24.388 T:3794514688 DEBUG: VideoPlayer::Sync - Audio - pts: 16367999.000000, cache: 287999.987602, totalcache: 570666.670799
08:44:24.388 T:3794514688 DEBUG: VideoPlayer::Sync - Video - pts: 16100000.000000, cache: 50000.000000, totalcache: 100000.000000
08:44:24.389 T:3560960768 DEBUG: CAMLCodec::SetSpeed, speed(1000)
08:44:24.389 T:3560960768 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(16000000.000000)
08:44:24.389 T:3534430976 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_RESYNC(16000000.000000)
08:44:24.389 T:3534430976 DEBUG: CDVDAudio::Resume - resume audio stream
08:44:24.391 T:4048651008 DEBUG: ActiveAE - start sync of audio stream
08:44:24.391 T:4039111424 INFO: CActiveAESink::OpenSink - initialize sink
08:44:24.392 T:4039111424 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:default
08:44:24.392 T:4039111424 INFO: CAESinkALSA::Initialize - Requested layout: FL,FR
08:44:24.392 T:4039111424 INFO: CAESinkALSA::Initialize - set digital_codec 0
08:44:24.392 T:4039111424 DEBUG: CAESinkALSA::Initialize -- unmuting HDMI
08:44:24.392 T:4039111424 INFO: CAESinkALSA::Initialize - Attempting to open device "default"
with
08:44:24.397 T:4039111424 INFO: CAESinkALSA::Initialize - Opened device "default"
08:44:24.400 T:4039111424 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
08:44:24.401 T:4039111424 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
08:44:24.401 T:4039111424 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
08:44:24.403 T:4039111424 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
08:44:24.403 T:4039111424 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 171 ms
08:44:24.404 T:4039111424 INFO: CAESinkALSA::Initialize - setting default aud_ch to 0
08:44:24.404 T:4078957136 DEBUG: ------ Window Deinit (Custom_Cache_Progress.xml) ------
08:44:24.404 T:4039111424 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
08:44:24.404 T:4039111424 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR
08:44:24.404 T:4039111424 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR (ALSA: none) (CEA: 0)
08:44:24.404 T:4039111424 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
08:44:24.404 T:4039111424 DEBUG: Output Device : Default (AML-M8AUDIO Analog)
08:44:24.404 T:4039111424 DEBUG: Sample Rate : 48000
08:44:24.404 T:4039111424 DEBUG: Sample Format : AE_FMT_S32NE
08:44:24.404 T:4039111424 DEBUG: Channel Count : 2
08:44:24.404 T:4039111424 DEBUG: Channel Layout: FL,FR
08:44:24.404 T:4039111424 DEBUG: Frames : 2048
08:44:24.404 T:4039111424 DEBUG: Frame Size : 8
08:44:24.532 T:4048651008 DEBUG: ActiveAE::SyncStream - average error of 67.116392, start adjusting
08:44:24.532 T:4048651008 DEBUG: ActiveAE::SyncStream - average error 25.116392 below threshold of 30.000000
08:44:24.585 T:4078957136 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is StepForward
08:44:26.812 T:3560960768 DEBUG: Previous line repeats 51 times.
08:44:26.812 T:3560960768 DEBUG: CPullupCorrection: detected pattern of length 1: 20000.00, frameduration: 20000.000000
08:44:26.819 T:4078957136 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is StepForward
08:44:32.086 T:4078957136 DEBUG: Previous line repeats 131 times.
08:44:32.086 T:4078957136 DEBUG: CRenderManager::PrepareNextRender m_QueueSkip:0 iter.pts:23.700 front.pts:23.680 renderPts:23.764 latency:0.067
08:44:32.087 T:4078957136 DEBUG: CRenderManager::PrepareNextRender m_QueueSkip:0 iter.pts:23.720 front.pts:23.680 renderPts:23.764 latency:0.067
08:44:32.102 T:4078957136 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is StepForward
08:44:36.786 T:4078957136 DEBUG: Previous line repeats 116 times.
08:44:36.786 T:4078957136 DEBUG: LIRC: Update - NEW at 85203:6a 0 KEY_RIGHT_UP linux-input-layer (KEY_RIGHT_UP)
08:44:36.802 T:4078957136 DEBUG: LIRC: Update - NEW at 85219:69 0 KEY_LEFT linux-input-layer (KEY_LEFT)
08:44:36.802 T:4078957136 DEBUG: OnKey: 169 (0xa9, obc86) pressed, action is StepBack
08:44:37.119 T:4078957136 DEBUG: CRenderManager::PrepareNextRender m_QueueSkip:2 iter.pts:28.720 front.pts:28.700 renderPts:28.797 latency:0.067
08:44:37.119 T:4078957136 DEBUG: CRenderManager::PrepareNextRender m_QueueSkip:2 iter.pts:28.740 front.pts:28.700 renderPts:28.797 latency:0.067
08:44:37.154 T:4078957136 DEBUG: CRenderManager::PrepareNextRender m_QueueSkip:4 iter.pts:28.800 front.pts:28.780 renderPts:28.832 latency:0.067
08:44:37.569 T:4078953216 DEBUG: CAnnouncementManager - Announcement: OnSeek from xbmc
08:44:37.569 T:4078953216 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnSeek
08:44:37.578 T:3794514688 DEBUG: CVideoPlayer::SetCaching - caching state 1
08:44:37.578 T:3794514688 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
08:44:37.578 T:3794514688 DEBUG: demuxer seek to: 183029189.000000
08:44:37.589 T:3534430976 DEBUG: CDVDAudio::Pause - pausing audio stream
08:44:37.615 T:3794514688 DEBUG: Seek - waiting for position 1376720284.
08:44:37.637 T:3836982016 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnSeek - data: {"item":{"id":1493,"type":"episode"},"player":{"playerid":1,"seekoffset":{"hours":50,"milliseconds":0,"minutes":50,"seconds":0},"speed":1,"time":{"hours":50,"milliseconds":179,"minutes":50,"seconds":29}}}
08:44:37.669 T:4078957136 DEBUG: OnKey: 169 (0xa9, obc86) pressed, action is StepBack
08:44:37.679 T:3517653760 INFO: CFileCache::Process - Source read didn't return any data! Hit eof(?)
08:44:37.722 T:3517653760 DEBUG: Thread FileCache 3517653760 terminating
08:44:37.742 T:3794514688 DEBUG: CSMBFile::Close closing fd 10000
08:44:37.749 T:3794514688 DEBUG: SeekTime - seek ended up on time 37920
08:44:37.749 T:3794514688 DEBUG: VideoPlayer: seek failed or hit end of stream
08:44:37.750 T:3794514688 DEBUG: CVideoPlayer::FlushBuffers - flushing buffers
08:44:37.802 T:3534430976 DEBUG: CDVDAudio::Flush - flush audio stream
08:44:37.802 T:3534430976 DEBUG: CDVDAudio::Pause - pausing audio stream
08:44:37.869 T:4078957136 DEBUG: OnKey: 169 (0xa9, obc86) pressed, action is StepBack
08:44:38.135 T:4078957136 DEBUG: Previous line repeats 1 times.
08:44:38.135 T:4078957136 DEBUG: LIRC: Update - NEW at 86552:69 0 KEY_LEFT_UP linux-input-layer (KEY_LEFT_UP)
08:44:38.755 T:3534430976 DEBUG: CDVDMsgGeneralSynchronize - global timeout
08:44:38.755 T:3534430976 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
08:44:38.755 T:3794514688 DEBUG: CDVDMsgGeneralSynchronize - global timeout
08:44:38.755 T:3794514688 DEBUG: CVideoPlayer::SetCaching - caching state 2
08:44:38.755 T:3794514688 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
08:44:38.755 T:3794514688 NOTICE: CVideoPlayer::OnExit()
08:44:38.756 T:3794514688 NOTICE: VideoPlayer: eof, waiting for queues to empty
08:44:38.756 T:3794514688 NOTICE: Closing stream player 1
08:44:38.756 T:3794514688 NOTICE: Waiting for audio thread to exit
08:44:38.765 T:3534430976 NOTICE: thread end: CVideoPlayerAudio::OnExit()
08:44:38.765 T:3534430976 DEBUG: Thread VideoPlayerAudio 3534430976 terminating
08:44:38.765 T:3794514688 NOTICE: Closing audio device
08:44:38.766 T:3794514688 DEBUG: CDVDAudio::Flush - flush audio stream
08:44:38.766 T:4048651008 DEBUG: CActiveAE::DiscardStream - audio stream deleted
08:44:38.766 T:4048651008 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
08:44:38.767 T:3794514688 DEBUG: Previous line repeats 2 times.
08:44:38.767 T:3794514688 NOTICE: Deleting audio codec
08:44:38.767 T:3794514688 NOTICE: Closing stream player 2
08:44:38.767 T:3794514688 NOTICE: waiting for video thread to exit
08:44:38.769 T:4039111424 INFO: CActiveAESink::OpenSink - initialize sink
08:44:38.769 T:4039111424 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:default
08:44:38.769 T:4039111424 INFO: CAESinkALSA::Initialize - Requested layout: FL,FR
08:44:38.769 T:4039111424 INFO: CAESinkALSA::Initialize - set digital_codec 0
08:44:38.769 T:4039111424 DEBUG: CAESinkALSA::Initialize -- unmuting HDMI
08:44:38.769 T:4039111424 INFO: CAESinkALSA::Initialize - Attempting to open device "default"
with
08:44:38.770 T:4078957136 DEBUG: ------ Window Init (Custom_Cache_Progress.xml) ------
08:44:38.771 T:4078957136 DEBUG: started alarm with name: iscachingtimer
08:44:38.777 T:3560960768 NOTICE: thread end: video_thread
08:44:38.778 T:3560960768 DEBUG: Thread VideoPlayerVideo 3560960768 terminating
08:44:38.778 T:3794514688 NOTICE: deleting video codec
08:44:38.778 T:3794514688 DEBUG: CAMLCodec::CloseDecoder
08:44:38.789 T:4039111424 INFO: CAESinkALSA::Initialize - Opened device "default"
08:44:38.793 T:4039111424 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
08:44:38.793 T:4039111424 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
08:44:38.793 T:4039111424 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
08:44:38.795 T:4039111424 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
08:44:38.796 T:4039111424 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
08:44:38.796 T:4039111424 INFO: CAESinkALSA::Initialize - setting default aud_ch to 0
08:44:38.796 T:4039111424 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
08:44:38.797 T:4039111424 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR
08:44:38.797 T:4039111424 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR (ALSA: none) (CEA: 0)
08:44:38.797 T:4039111424 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
08:44:38.797 T:4039111424 DEBUG: Output Device : Default (AML-M8AUDIO Analog)
08:44:38.797 T:4039111424 DEBUG: Sample Rate : 44100
08:44:38.797 T:4039111424 DEBUG: Sample Format : AE_FMT_S32NE
08:44:38.797 T:4039111424 DEBUG: Channel Count : 2
08:44:38.797 T:4039111424 DEBUG: Channel Layout: FL,FR
08:44:38.797 T:4039111424 DEBUG: Frames : 2048
08:44:38.797 T:4039111424 DEBUG: Frame Size : 8
08:44:38.800 T:4048651008 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
08:44:38.823 T:3794514688 DEBUG: Previous line repeats 1 times.
08:44:38.823 T:3794514688 DEBUG: OnPlayBackEnded: play state was 2, starting 0
08:44:38.824 T:3794514688 DEBUG: Thread VideoPlayer 3794514688 terminating
08:44:38.824 T:4078953216 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
08:44:38.824 T:4078953216 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
08:44:38.825 T:4078957136 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
08:44:38.825 T:4078957136 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
08:44:38.836 T:4078957136 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
08:44:38.841 T:3836982016 DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnStop - data: {"end":true,"item":{"id":1493,"type":"episode"}}
08:44:38.843 T:4078957136 DEBUG: ------ Window Init (MyVideoNav.xml) ------
