OMSC and kodi : permanent crash
I a newbie here so I look for some help for three problems I have.
Device used : Raspberri Pi 2 with latest version of OSMC
Here s the first (and most important one).
For an unknown reason, 2 times on 3, when I go to video/Library and scrolls to particular folder(located on a synology nas over my 1 Go network) and try to get in, the whole kodi freezes and crash.
It is true the folder I want to get in contains a very long list of subfolders but unless you are aware of a particular limit, I don t understand why i have this message ‘Busy’ and then it just stops
Any idea is welcome !!
IloveFriday
PS: I orgaise a VM on windows 10 with the same conditions (kodi 16.1+network+nas) and not a single issue so far…
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us help you.
@ActionA Thanks for the reminder
After some further tests, it appears that the skin I was using was the main cause of all my troubles :frowning:
Getting back to confluence solved ALL the pbs !
