My assumption is that all drives from /etc/fstab are mounted before /etc/rc.local is executed ony my RPI2.
My /etc/fstab looks like the following:
UUID=70BCEC34BCEBF310 /mnt/wde4tb ntfs rw,nosuid,nodev,relatime,uid=1000,gid=113,permissions,umask=007,nofail 0 0
UUID=74A6-7F41 /mnt/sd64gb vfat defaults,nofail 0 0
UUID=2efde1bd-42b1-428e-a76d-5910d62a0e9a /mnt/ks32gb ext4 defaults,nofail 0 0
If I run this command from the shell I get proper response:
osmc@osmc:~$ sudo hdparm -S 241 $(mount | grep wde4tb | awk
'{print $1}')
/dev/sda1:
setting standby to 241 (30 minutes)
I have put the same command in /etc/rc.local (without sudo) but looks like it is not executing upon reboot.
In order to check what is going on I have put some diagnostic in the /etc/rc.local file:
sleep 10
echo "start" > /home/osmc/rc.local.output
echo '-----mount-----' >> /home/osmc/rc.local.output
mount >> /home/osmc/rc.local.output
echo '-----mount grep-----' >> /home/osmc/rc.local.output
mount | grep wde4tb >> /home/osmc/rc.local.output
echo '-----mount grep awk-----' >> /home/osmc/rc.local.output
mount | grep wde4tb | awk '{print $1}' >> /home/osmc/rc.local.output
echo '-----hdparm-----' >> /home/osmc/rc.local.output
hdparm -S 241 $(mount | grep wde4tb | awk '{print $1}') >> /home/osmc/rc.local.output
echo "end" >> /home/osmc/rc.local.output
After rebooting the /home/osmc/rc.local.output looks like the following:
start
-----mount-----
devtmpfs on /dev type devtmpfs (rw,relatime,size=370540k,nr_inodes=92635,mode=755)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /run type tmpfs (rw,relatime)
/dev/mmcblk0p2 on / type ext4 (rw,noatime,stripe=1024,data=ordered)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=23,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
/dev/mmcblk0p1 on /boot type vfat (rw,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
/dev/sdb1 on /mnt/ks32gb type ext4 (rw,relatime,data=ordered)
/dev/sdc1 on /mnt/sd64gb type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
sysfs on /sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq type sysfs (rw,relatime)
As you can see there is ks32gb and sd64gb from fstab, but there is no wde4tb (sda1) drive.
After boot process is completed, mount shows the wde4tb drive:
osmc@osmc:~$ mount
/dev/sda1 on /mnt/wde4tb type fuseblk (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=75108k,mode=700,uid=1000,gid=1000)
Can someone explain to me why I can’t see wde4tb mounted from rc.local but I can see other drives?
