Hello everyone,
I’m attempting to install OpenVPN on my Pi 2 with OSMC. I downloaded and installed the OpenVPN 3.0.0 zip and attempted to follow these instructions:http://brianhornsby.com/blog/how-to-setup-your-vpn-client
However at step 8 there is no /storage/ folder and osmc is not capable of creating a new folder at root.
Should I just change the referenced files in the .ovpn config file to any other folder that exists in root, then place all necessary files there?
Thank you!
